s10 2.2l mass air flow sensor
Old Mar 14, 2007 | 12:28 AM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default s10 2.2l mass air flow sensor
Hello. Does it make a difference if I use a ported mass air flow sensor that come off a 2.2l S10 on a 2000 4.3l blazer? Thank.
Old Mar 14, 2007 | 01:34 AM
20Blazer00's Avatar
Default RE: s10 2.2l mass air flow sensor
It can because the computer is expecting to see a specific amount of airflow and the 2.2L MAF might not have the flow needed to keep the computer happy...also connectors might be different....
Old Mar 14, 2007 | 09:11 AM
When it comes to MAF sensors, you have to make sure that their frequency response is the same given an equal flow rate of air across the flow range the 4.3L requires.
1st thing I'd check is to see if the MAF sensor is even the same size as the 4.3L MAF. The 4.3L MAF is the same one used on the 5.7L v8. Are you replacing it in hopes of gaining performance?
Old Mar 14, 2007 | 09:42 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
The 2.2l does not use a MAF sensor, it uses a MAP sensor that senses pressure in the intake, where the MAF measures the air flow into the motor. The 4.3l uses both sensors.
Old Mar 14, 2007 | 09:44 PM
ORIGINAL: Kordog
Whoa. You just blew my mind. Thanks for the help.
puckrocker
Jul 12, 2011 10:29 PM
2k2Blazer
Oct 26, 2009 04:20 PM
truesmack
Aug 9, 2009 08:51 PM
O_P_PLaya
Headers, Intake, & Exhaust
Sep 2, 2007 01:22 PM
