Scan Tool
Old Apr 3, 2020 | 10:00 PM
blazerpower's Avatar
blazerpower is on a distinguished road
Default Scan Tool
I have a 96 Blazer 2wd. I am looking for a scan tool that can read all the systems in the vehicle. Also would like to be able to perform function tests and whatever is needed for diagnostics. Only thing I have really seen talked about online in general are the tech 2 scanners, but I'm not trying to shell out that much to only be able to read 1 set of vehicles. I have tried searching the forum but didn't really get any results. Any help would be greatly appreciated!!
Old Apr 3, 2020 | 10:33 PM
LesMyer's Avatar
Best cheap multi-system scanner out there IMHO. Does a heckuva lot with the different systems including crank sensor relearn and brake bleed and injector balance, etc - but It's not a TECH 2 so don't expect everything in the factory diagnostic charts to be available. AFAIK the I-link400 functioning for GM enhanced PIDs on a 1996 Blazer is yet to be proven. 1996-1997 have given some problems with cheap scanners in the past. Buy it from Amazon (buy for GM and definitely do the software update). Return it if it doesn't work for you. Let us know the function on your 1996. Don't believe it does 4WD system at all, but it does powertrain, SIR, ABS, transmission, body, HVAC, etc on my 2001.
https://blazerforum.com/forum/2nd-ge...n-tool-100119/
Old Apr 4, 2020 | 10:25 AM
eshaw's Avatar
So, has anyone bought and tried out the Chinese Tech 2 yet?
Old Apr 4, 2020 | 04:10 PM
I have been using an UltraGauge mostly for monitoring my transmission fluid temperature. It also works to set alarms; e.g. over-temp.
Because the minimum number of data readouts is four, I display the Trans Temp, the Coolant Temp, the corrected speed (I have larger tires) and one more that I'll change depending on the mood I'm in.
It of course also reads the standard ODB-II codes.
Old Apr 4, 2020 | 05:03 PM
93S10TahoeLT's Avatar
I have both the $20 one from Walmart and Torque Lite Bluetooth with a 34t5? Bluetooth adapter off Amazon and both yield very good results. It really is cool to see manifold pressure in Hg, open loop vs closed, customizable graphs..
Christine, I have something like that for voltage I stick in the cigarette lighter/power port.
kevinph
Feb 25, 2019 09:24 PM
blazertom
Jul 29, 2015 02:12 PM
babeba67
Dec 2, 2013 01:42 PM
Red 96
Mar 30, 2012 08:17 AM
pruitt801
Jul 4, 2010 02:14 AM
