Scary brake problem.....help
Old Jun 23, 2010 | 05:43 PM
Hizapitt's Avatar
Hizapitt is on a distinguished road
Default Scary brake problem.....help
I have a 96 4x4, disc front and drum rear. It must have anti lock brakes on the front.
Sometimes when I step on the brakes the right rear locks up. On top of that, at times if I press harder the anti locks kick in and I can not stop at all.
I have notice that if I am on gravel, rain, snow, mud, ( any slippery road) the rear tire locks and the front wont stop it.
I have replaced both rear adjusters and bled the brakes. No help.
I have heard that there is a tech bulletin about the front sensors creating problems also possible to unplug the anti lock brakes. Any suggestions?
My wife needs to use the truck but I am afraid to let her.
Old Jun 23, 2010 | 05:50 PM
Frankiesurf's Avatar
Frankiesurf is on a distinguished road
Pull the back wheel apart and check the adjuster. Pull it out and make sure it is free. Take it apart, hit it with a wire brush and give the threads a coat of anti-seize. When you reinstall it, put on the drum and adjust it from the back, making sure you can still spin the drum but it has a little resistance.
This should take care of the back wheel. I am no ABS expert so I will let someone else chime in on that.
Old Jun 23, 2010 | 06:03 PM
Hizapitt's Avatar
I put new adjusters on it, they are free and should be working.
bhsdrillr
Mar 12, 2013 09:25 PM
OKBlazer01
Dec 13, 2011 09:46 PM
matthewcarter1014
Jun 2, 2008 09:30 PM
bdscholes71`
Oct 7, 2007 02:59 PM
TripleBlackBlazer
Sep 5, 2007 04:55 AM
