seized rear caliper pin
Old Aug 12, 2011 | 10:01 PM
stlunatics2oo3's Avatar
stlunatics2oo3 is on a distinguished road
Exclamation seized rear caliper pin
the passenger rear caliper pin seems to be seized, I put an 18mm on the end of it and can rotate it but it doesnt seem to come out any. is there any other way to get them out so I can replace them? thanks in advanced this is on a 98 blazer 2wd
thanks
Jeremy
Old Aug 12, 2011 | 10:23 PM
The bolt goes through the caliper & into the pin. If all you are doing is turning the bolt, you have to hold the pin on the other side of the caliper, between the caliper & the rubber boot.
Old Aug 12, 2011 | 10:37 PM
I can get the caliper off, im talkin about the slider pin, I cant get the pin out to lubricate or replace it.
Old Aug 12, 2011 | 11:39 PM
If its that bad, do yourself a favor and go grab a new caliper bracket & pin kit. It isn't worth the hassle. Sure, you could screw with it until you get it freed up, but you would waste your time & money and still need a new pin kit and likely have an enlarged hole in the bracket when you got it all done. The bracket should only be ~$10 and the pin kit just a bit under that.
Old Aug 13, 2011 | 01:01 PM
yeah you was right I couldnt get the pins out so I bought a loaded caliper that came with the bracket and all, thanks again
Never_grew_up
Jan 19, 2014 08:04 PM
lx40
May 21, 2012 08:27 AM
01BLZRX
Aug 6, 2010 07:30 PM
pigmak
Nov 4, 2007 07:21 PM
pigmak
Nov 4, 2007 02:26 PM
