self-engages auto 4x4 or 4 Hi
Old Mar 1, 2022 | 03:39 PM
my old blazer's Avatar
my old blazer is on a distinguished road
Unhappy self-engages auto 4x4 or 4 Hi
This old 99 LT Blazer, 119000 miles, self-engages the auto 4x4 or 4 Hi. Today I replaced the 4-button switch on the dash. After driving just a few miles it did it again. About 3 years ago I did replace the TCCM due to a similar problem. At over $200 now I hate to just throw money at it. Any other possible solutions would be helpful.
Old Mar 2, 2022 | 05:09 PM
El_Beautor's Avatar
First thing I'd check is for a loose connection, or corrosion on the plugs at the TCCM behind the passenger side kick panel. It's quite common for the wires there to become corroded. There's a few threads on here about cleaning the pins and connectors.
Old Mar 2, 2022 | 06:56 PM
Been there done all of that. The replacement TCCM had a big glob of silicon grease in it and is still in good condition. I'm thinking could it be a wheel speed sensor???I'll have to dig out the old Clinton's and see if there is wiring diagram for the system.
Old Mar 10, 2022 | 08:19 PM
Mods's Avatar
is the Actuator motor actually moving or is the front axle locking in?
Old Mar 10, 2022 | 11:06 PM
Unhappy Yes
Yes on both. I mean it locks up tight just like it would if I intentionally pushed either button. Day before yesterday I replaced the transfer case actuator, a real pain. I drove it about 30 minutes and stopped for a couple of minutes at a friends, it did again right on start up. Now what??? Can a code reader pick up a problem like this?
Old Mar 12, 2022 | 07:58 AM
LannyL81's Avatar
Is the 4x4 switch indicating AUTO or 4HI when it does this?
Might be the 4x4 vacuum switch that applies vacuum to the actuator under the battery is switching on its own. Not sure where the switch is on a '99...you will need to research that.
Just a quick thought...
Old Mar 12, 2022 | 11:38 AM
Some sensor is telling this system to lock up and it's working perfectly. But I don't want it to engage randomly. The Snap-On scan tool says rear wheel speed sensor shorted and brake light switch is bad. Well, this 4x4 with automatic trans doesn't have rear wheel speed sensors. There is a sensor in the transfer case on the upper right side of the tail housing??? Two years ago, when transmission died, I should have sold this thing for junk. But it's still a nice looking and comfortable little Blazer with lots of miles left in it.
Old Mar 12, 2022 | 01:43 PM
Mods's Avatar
you have multiple speed sensors, one on each front wheel, and the transfer case if i remember right has an Input and output shaft sensor.
jprife
Jan 20, 2014 03:26 PM
ph4ze
Oct 15, 2011 02:59 PM
blazerwithballs8
Mar 2, 2009 12:30 PM
gewebb
Dec 19, 2007 10:36 AM
nhorn1983
Jan 31, 2007 06:23 PM
