Serpentine Belt
Old Apr 4, 2007 | 01:16 PM
99BlazerZR2's Avatar
99BlazerZR2 is an unknown quantity at this point
Default Serpentine Belt
I noticed this morning I have a noisy serpentine belt, is there any danger in using belt dressing or anything else to quiet it?
I've heard that oil based products are not advised, and even one person that's used bar soap by rubbing the inside of the belt with it?
The belt tension is just fine and all bearings are as well. Any tips would be appreciated, thanks.
Old Apr 4, 2007 | 04:55 PM
nj4x4blaze's Avatar
Default RE: Serpentine Belt
It's better of just replacing the belt. It's not hard at all and only takes a few minutes to do it.
Old Apr 4, 2007 | 05:21 PM
magnum434's Avatar
magnum434 is an unknown quantity at this point
use goodyears "gatorback"... :-)
Old Apr 5, 2007 | 04:08 AM
kerander's Avatar
kerander is an unknown quantity at this point
It's so easy to change the belt of these, I just get a belt and hop to it; takes 3 - 5 mins if you look at therouting diagram [8D]. Plus I have heard bad things about belt dressings.
Old Apr 5, 2007 | 04:12 AM
Chevy Lover's Avatar
If you use a belt dressing type product, the noise goes away temporarily while coating the pulleys with crap that's so hard to clean off that it will affect the new belt that you will eventually put on to replace the noisy one.
Best choice is replace the belt. While the belt is off check that the pulleys spin free.
Old Apr 5, 2007 | 12:34 PM
Thanks everyone, a new belt seems the way to go, now if it would stop snowing and get a bit warmer.
Old Apr 8, 2007 | 03:31 PM
Peco's Avatar
Peco is an unknown quantity at this point
Get a Goodyear Gatorback Belt Part # 4060952. Just got one for my ZR2 and it so much quieter now.
Old Apr 12, 2007 | 11:35 PM
thecoutures's Avatar
thecoutures is an unknown quantity at this point
I went ahead and used the cheap value belt at Auto zone would this cause my belt to squeak a little when in gear? It's been raining here lately so I don't know if it's water up on the belt as well but I've noticed it as well when it isn't raining?
Old Apr 16, 2007 | 06:27 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
New belts are quieter, but when it comes to belts, buy GOOD ones. Don't save a buck by going cheap.
Old May 17, 2009 | 09:04 PM
mroach06's Avatar
mroach06 is on a distinguished road
i need a serpentine belt diagram for a 96 blazer.
