Service 4wd warning
Old Nov 6, 2008 | 08:25 PM
mikeymo67's Avatar
mikeymo67 is an unknown quantity at this point
Default Service 4wd warning
On my way home from work tonight I inadvertently hit the four hi button while adjusting the air vent that is next to the 4x4 control buttons. The service 4wd light came on.I pulled over and tried to put in back in 2 hi. I heard the usual click from underneath the dash. The clicking kept repeating until it went back into 4 hi. I was able to get it to stay in auto 4wd for awhile, but eventually all of the indicator lights on the buttons went out and wouldn't come back on and the service 4wd remained lit.
Obviously I'm going to take it to get it checked out, but I thought someone here might know something that I could do that I wasn't aware of. Also, assuming it's in auto 4wd, is it okay to drive? I drive quite a bit and need to at least drive tomorrow.
Thanks!!
Old Nov 6, 2008 | 08:30 PM
Default RE: Service 4wd warning
If you remove the 4WD fuse and reinstall it, it should reset to 2HI. Beyond that, the Auto4wd transfer case control system is quite complex in its operation which makes it very difficult to trouble shoot with out the proper diagnostic tools.
Old Nov 6, 2008 | 08:38 PM
mikeymo67's Avatar
ORIGINAL: swartlkk
Thanks, but pulling the fuse was one of the first things I did. I'll just take it in and get it checked out. Do you think it will be okay to drive?
Old Nov 6, 2008 | 08:41 PM
Drive it a bit in tight circles to see if you get any binding in the drivetrain. If you do not notice any, then you should be good to drive it. If you do notice binding, you can disconnect the vacuum line to the front axle vacuum solenoid on the firewall which will disengage the front axle.
Old Nov 7, 2008 | 06:27 AM
mikeymo67's Avatar
ORIGINAL: swartlkk
It's definitely binding. Where on the firewall is the solenoid. My knowledge here is fairly limited. Thanks!
Old Nov 7, 2008 | 06:43 AM
Should be close to the center. It will have an electrical connection and two vacuum lines.
Old Nov 7, 2008 | 08:15 AM
mikeymo67's Avatar
ORIGINAL: swartlkk
Thanks for the help! I wasn't sure if I needed to pull one or both so I pulled both. I hope that doesn't cause any problems. Thanks again!
Old Nov 7, 2008 | 08:45 AM
So long as you remember where they came from and plug them with something (golf tees work great for this), you should be good. You probably could disconnect the electrical connection as well and done the same thing.
Old Nov 7, 2008 | 11:31 AM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
ORIGINAL: swartlkk
if it's a physical failure of that valve, it might be leaking vacuum when it should be in 2HI, thus partially engaging 4HI, so unplugging electrical in that case wouldn't have the desired effect ... if it's an electrical failure of that valve, plugging/unplugging probably wouldn't matter there either, would it?
Old Nov 7, 2008 | 12:22 PM
In 2HI, the vacuum pressure is released at the transfer case. But he is having trouble getting it back into 2HI.
parks336
Dec 1, 2023 12:34 PM
rgkkw1221
Aug 5, 2014 06:23 PM
Geir
Oct 9, 2011 08:51 PM
2001 ZR2
Jan 16, 2010 12:39 PM
ESKYMOPACK
Jun 20, 2009 07:16 PM
