Service AWD light questions
About a month or so ago, I replaced my transfer case. For a while, it was fine. AWD was working great, no crow hop, no binding, all that good stuff.
Just recently, the service AWD light came on. When I turn the key on, I hear a clicking coming from the passenger's kick panel and the AWD light stays on. The clicking stops after a couple of seconds. I just went and tried it out on a nearby dirt road, and I think the AWD is working in and out. When I put it to the floor, I feel the rear wheels slipping and acting like traction control is coming on like in my Alero. It jumps. It's like slip, grab, slip, grab. What could be the culprit? I'm hoping just corrosion on the tccm.
99 Olds Bravada NP136
The code reader will tell you what it is most likely. There is no cost in checking for TCCM corrosion and ensuring you have no wires loose it broken, but beyond that you'll be throwing money at it.
Something else that was recommended to me was to ensure the fluid was fresh with autotrack II fluid, which you can get at the dealer or on Amazon as I have found.
I'd recommend finding someone with a scanner capable of reading the NP136 codes. I suspect it's either the transfer case clutches (as you said slip, grab, slip, grab), or the encoder motor itself, but this is just my opinion. You can't go wrong checking for corrosion in the TCCM connectors or plugs around the encoder motor.
No idea, I'll check what mine does when I leave work today and let you know.......
Mine clicks when I turn the key also, so sounds like a relay click for power to the encoder motor. Again makes sense to get the codes read but I'd bet it's your encoder motor.
ntjoe
11-12-2012 05:35 PM
98BravadaST
01-16-2010 12:35 PM
rednekk
04-17-2008 09:09 PM
