SES Light only on in accessory position
Old Aug 22, 2024 | 11:16 PM
BustedKnucles's Avatar
BustedKnucles is on a distinguished road
Default SES Light only on in accessory position
1999 Blazer 4x4
What's up y'all back at it again with more problems on ol "reliable" so issue im having right now is I have an SES light but only when the key is in the accessory position and it's not throwing any codes but the print out from AutoZone says non emissions compliant or not emissions ready, something like that...just wondering what the issue may be or if anyone else has had a similar issue.. from what I can tell I have all my vacuum issues fixed.. has the slightest rough idle and maybe a very minor exhaust leak but nothing I can track down at home because if it is leaking it's almost non existent.. thanks in advance! Hope everyone's having a good night
Old Aug 26, 2024 | 01:48 PM
Anyone? Lol
Old Aug 26, 2024 | 05:29 PM
Since the engine is not running while in the accessory mode, the check engine light will be illuminated. It is normal, but I can see where it could send give someone the wrong impression.
Old Aug 27, 2024 | 11:26 PM
Thing is after all the other dash lights go out as normal it stays illuminated.. that's what's got me confused as well as the code reader coming back and saying non emissions compliant
Old Aug 28, 2024 | 07:32 PM
'Emissions not ready' is what will be stated when all of the drive cycle monitors have not completed their tests successfully. This will happen when the codes get reset. The system needs to go through all of the monitor tests to make sure that everything checks out. You can look up "GM Drive Cycle" to see what you can do to get all of the emissions monitors to run their test and hopefully pass to show complete. If you have an evap leak, then that monitor will likely fail.
As far as the light being on, as I have said already, that is completely normal. The engine is not running so the light is illuminated. Nothing to see here, move along.
StarScreamin
Feb 16, 2019 06:56 PM
NipZ
Sep 5, 2015 07:41 AM
Tuna
23
Jun 6, 2015 06:17 PM
bagged02
May 23, 2012 09:01 PM
stevette
Mar 26, 2009 07:59 AM
