SES surprise
Old Aug 19, 2018 | 08:28 PM
Carbon78's Avatar
Carbon78 is on a distinguished road
Default SES surprise
Well, I noticed the other day when starting my 2003 blazer LS that the SES light wasn't lit up. I decided to take it to see if it had any codes or not. When they hooked it up, it came up with 20 codes. Thankfully some were duplicates but after wiping those out, I was still left with 14. Any suggestions on what to hit first and how to touble shoot them to fix it would be appreciated. The codes are as followed:
B0036
U1000
U1096
U1064
C0226
C0223
C0222
C0221
P0101
P0128
P0335
P0446
P0452
P0463
Old Aug 20, 2018 | 06:00 AM
GreenBlazer2002's Avatar
B0036
U1000
U1096
U1064
C0226
C0223
C0222
C0221
P0101
P0128
P0335
P0446
P0452
P0463
your truck thinks it's totaled.
Old Aug 20, 2018 | 07:01 AM
Here's the description on all of the codes:
I would start with the Uxxxx codes. If there is a communication error in the Class 2 data bus, very weird things can happen. To that end, I would have a serious look at the ignition switch as it tends to get erratic as it starts to go. You can read more about the ignition switch by having a look at the Anatomy of the Ignition Switch thread I created years ago.
Old Aug 21, 2018 | 12:08 AM
Carbon78's Avatar
If the ignition switch was having issues, would I have issues starting the vehicle? It starts every time without issue so far. Only time it didn't was when the started went out.
Old Aug 21, 2018 | 06:37 AM
The thread I mentioned above shows the inside of the switch along with wiring diagrams and connector pinouts. As you will see, there are a total of 5 different circuit contacts inside the switch. Only one contact is responsible for energizing the starter relay and since the starter circuit has a relay, there really isn't much load on the contact.
The IGN1 & IGN3 circuits have much more current flowing through the contacts in the ignition switch and are the ones that typically will burn out. The IGN1 circuit specifically powers the SIR and GAUGES fuses among others. The IGN3 circuit powers the ABS system among others.
Testing the contacts requires a multimeter and can be done by testing the resistance or voltage drop from the input to the output sides of the contacts. You would want to disconnect the ignition switch connector for the resistance test while the voltage drop test is done with everything connected and powered up. For IGN1, you'll test the large red wire (B1) to the large pink wire (C5). For IGN3, large red wire with white stripe (D2) to the large orange wire (C6). The contacts for IGN1 are closed in RUN & START while the contacts for IGN3 are closed in RUN only.
Blazer1087
Aug 28, 2012 10:41 AM
levey
Nov 22, 2011 06:28 PM
99 blazer
Nov 8, 2011 07:24 AM
Kook
14
Sep 21, 2011 09:02 AM
Blazeme
Oct 31, 2009 12:57 PM
