Setting the timing on a 96' model
Old Jun 28, 2016 | 02:09 PM
  #51
Graveyard's Avatar
Graveyard is on a distinguished road
Hey Les,
Got my Bafx obdII scanner. Everything connects I choose Gm, Powertrain, full autoscan, obd2...and address, then it begins to scan. After it finishes I get the message " no supported Pids". After that nothing works on the Car gauge pro. Any suggestions?
The vehicle is a 96' model Chev Blazer with a 4.3
Later
Old Jun 28, 2016 | 02:11 PM
  #52
Graveyard's Avatar
Just to be sure, I'm going to try it with my Galaxy tablet.
Old Jun 28, 2016 | 02:52 PM
  #53
Graveyard's Avatar
Ok, if I use " All (obd II Generic)" it connects and I can add gauges but not a cam retard.
It's not in the "generic" choices.
When I go back to "gm" blah, blah... It get unsupported Pids.
Old Jun 28, 2016 | 03:04 PM
  #54
Racer_X's Avatar
Racer_X is on a distinguished road
Are the gauges you add showing data when the engine is running?
Did you go into the bluetooth settings and "pair" with the OBD-II bluetooth interface?
When I first got my BAFX adapter, I think Car Gauge Light and Car Gauge Pro gave very unhelpful error messages when I didn't pair with the OBD-II bluetooth adapter. The Torque Light app told me it couldn't find an OBD-II adapter and suggested pairing to a bluetooth device or setting up WiFi connection to a WiFi device.
Last edited by Racer_X; Jun 28, 2016 at 03:42 PM. Reason: Added comment about error messages.
Old Jun 28, 2016 | 04:31 PM
  #55
Graveyard's Avatar
Well, the gauges are working when it connects using the generic choice. When I choose to connect with the gm powertrain, it does a scan, and the message says" unsupported pids" and goes no further. I can setup gauges but they don't respond.
Old Jun 28, 2016 | 05:19 PM
  #56
Graveyard's Avatar
One more thing, It works on my 2000 ford f150. All the pids show up and are functional.
Old Jun 28, 2016 | 06:30 PM
  #57
LesMyer's Avatar
Car Gauge Pro was really designed for Ford and Nissan. It does a LOT on my 2008 Ford Ranger including airbag and brakes Please see my post in the other thread on CMP retard. Car Gauge Pro may be having trouble with 1996 for some reason.
Also, for anyone using Car Gauge Pro the CMP retard to use on the Blazers is indeed the single asterick one. I tested today and single asterick was 0.7 while the double asterick was 1.2. Other software I have matches the 0.7 for CMP retard on my vehicle.
jojocarreno
May 27, 2011 12:27 PM
maxi52.1
Aug 26, 2010 07:43 PM
riddikstraaf
Aug 8, 2010 05:14 PM
A2Zcustomupholstery
Aug 4, 2010 08:07 PM
justin1795
Mar 27, 2009 07:55 PM
