SEVERE Coolent leak please help :(
Old Jun 24, 2012 | 08:54 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
lower intake manifold gasket
Old Aug 30, 2012 | 11:48 PM
nolareese's Avatar
nolareese is on a distinguished road
Default loose bolts
would a pressure test show the leak from where the hose connects above the water pump if the bolts are loose?
Old Aug 31, 2012 | 02:23 PM
nolareese's Avatar
Originally Posted by Rottidog
I'd lean towards the intake manifiold gasket if the thermostat housing is dry as well as the upper rad hose.
Maybe try getting a mechanics mirror on a flexable stick, look around & try to spot where it's coming from.
will a pressure test show that leak, i think i have the same problem
Old Sep 1, 2012 | 10:38 AM
dobyken's Avatar
dobyken is on a distinguished road
It should show all leaks other than an internal intake manifold gasket leak in which case you would hear but not see it. I had to replace the riser pipe on top of the engine because it had rusted through...as you mentioned it's rusted you might want to replace it even if it's not leaking YET. Since you have a pool of coolant on top of the intake manifold then it's most likely not the LIM gasket. I think I paid $10 for a pressure test at my local garage vs about $50-60 to buy the tool. Maybe Autozone has one in the loan a tool program.
Old Sep 2, 2012 | 08:29 AM
nolareese's Avatar
im am going to rent a pressure tester in the next day or so to see where the leak is coming from, at least i have the advantage that it is a very slow leak at the moment. Will the pressure test make any worst than it is now?
Old Sep 2, 2012 | 09:56 AM
dobyken's Avatar
No, you only pump it up to 16 pounds of pressure which is the same as the operating pressure. If there's a big leak it's hard to even get it up to pressure.
Old Sep 3, 2012 | 10:34 AM
nolareese's Avatar
Thumbs up
hey thanks for the info, i really appreciate it. i will post the outcome
Old Sep 3, 2012 | 03:15 PM
Buck731's Avatar
Buck731 is on a distinguished road
Intake Manifold Gasket... Mine leaked really bad... it would empty the radiator and surge tank in a 10 mile trip. they can leak!!!!
dharvey4651
Apr 3, 2015 05:30 PM
antman94
Mar 27, 2015 08:26 AM
jmac219
Oct 16, 2010 08:33 AM
redskins1
27
Mar 12, 2010 06:04 PM
lry040
Apr 15, 2008 06:25 PM
