Shaky Brake
Old Apr 9, 2006 | 01:33 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
Default RE: Shaky Brake
thanks for the input, i have seen those pads. I also don't want performance ones on my truck. Unfortunately, sometimes, those stops can't be avoided sometimes.
Old Apr 10, 2006 | 04:50 PM
Hanr3's Avatar
I don't think the dealer will cover it under warrenty, its a normal wear and tear item.
Old Jul 7, 2006 | 02:54 PM
Canadian88's Avatar
Update.
I put new rotors and pads on the truck, and it is smooooooth as silk. I know its been a while, but i'm just so happy to have smooth brakes for once. Does anybody know a break-in procedure for new rotors and pads? I know that you have to go light on them for a little while, but for how many miles?
Old Jul 7, 2006 | 03:25 PM
Actually as far as break-in proceedure, I have gone by one that I remember from way back until recently. With the newer pad materials and rotor finishes, you really don't have to bed them in. Just don't go auto-crossing it and you should be fine.
The old proceedure involved 5-6 stops from 30mph with enough time to cool the brakes between stops, then 5-6 from 45 with time to cool between, finally 5-6 from 60 with time to cool. That was all. Now the stops weren't panic stops by any means, but normal stops. Not too light, but don't slam on them. And this should have been done right after installing the brakes, no time in-between.
Old Jan 19, 2007 | 04:35 PM
elementx440's Avatar
elementx440 is an unknown quantity at this point
ORIGINAL: Canadian88
I have a full warranty on the car, anybody know if it covers brakes? i'm not sure.
probably not since it's wear-and-tear... But if you do buy a set, they usually come with a lifetime warranty, or a few years... and then you're covered for future events.
It's so much cheaper to replace break pads too early, then to wait longer and have to swap rotors too. Rotors are $50+ a piece, pads are what, $20 for your whole front end?
I have had to make some quick stops (caused by dumbass drivers(not me)).
that's what brakes are for... it wont lessen the normal life. maybe you're a "dumb *** drivers" after all for following too close?
Old Jan 19, 2007 | 05:23 PM
Such intelligence... Would have thought maybe you'd look at the age of the thread and decided better... Oh well... Last comment shows some class though... Geez.
Old Jun 23, 2008 | 10:11 PM
socrplyr38's Avatar
socrplyr38 is an unknown quantity at this point
i have a 2002 blazer extreme and i replaced the rotors and pads and i still have that problem of pulsating brakes and it has to be the VSS sensor or ABS computer...
walt
Old Jun 24, 2008 | 06:38 AM
I moved your thread into a new topic instead of dragging up this ancient topic!
You can find it by CLICKING HERE.
iamchevyman5
Sep 23, 2011 12:11 PM
musclecar70sfan
Dec 12, 2010 03:40 PM
santmire
Oct 12, 2009 11:42 AM
joey
Dec 17, 2006 09:47 PM
Blazin 4x4
Oct 14, 2005 01:03 PM
