Shifting Problems
Old Jun 14, 2011 | 08:01 PM
knagy20's Avatar
knagy20 is on a distinguished road
Default Shifting Problems
I have a 2001 Blazer Lt 4wd. When you try to pass another vehicle, the tach red lines, the vehicle jerks like the transmission doesn't know what gear to be in and the motor sounds like it has marbles in it. After you back off the throttle and drive regularly, the the truck jerks like it was just shut off. No codes come up and I don't see any fluctuations in any of the gauges, except the tach drops then immediately picks back up. Anyone have any thoughts???
Old Jun 14, 2011 | 11:51 PM
chaoticdopey's Avatar
chaoticdopey is on a distinguished road
it could be a bad VSS (Vehicle Speed Sensor) could be telling the ECM to shift at the wrong time, pick one up there only $20
Old Aug 25, 2011 | 02:54 PM
knagy20's Avatar
Sorry it took so long to get back. Chasing a P0302 and I need to get it through emission inspection. Replaced the switch. Works better but when the tach hits about 4k, it starts acting up again. Thanks for the idea.
Old Aug 25, 2011 | 09:09 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
DO NOT guess what is wrong! Its expensive. Troubleshooting the problem is cheap! That VSS could have been tested.
Personally I have not had this problem so I really cant give you a direction to go. But I can tell you there are people here who will help you troubleshoot it.
Good luck!
fiXXitup
Sep 2, 2009 12:47 AM
TylersBlazer
Jan 24, 2009 09:07 PM
jbouchard09
May 14, 2008 09:11 AM
96jimmy4x4in
Oct 7, 2007 09:23 PM
farmboy191
Jun 11, 2007 02:24 PM
