HELP I am running out of time
Old Aug 22, 2011 | 08:10 AM
MikeRo's Avatar
MikeRo is on a distinguished road
Default HELP I am running out of time
Hey, just had my blazer inspected for the second time today and it failed for idle carbon emissions again. The problem is that i am going away for the week and need to move back to Connecticut on Saturday.
On Friday it failed with 367ppm when it has to be under 220ppm. So i put Chevron Techron Concentrate and Shell V-Power gas in to try and clean up the system. Got tested again today and now it read 536ppm. Anyone know what i can do? Is it because i am still burning off the Chevron cleaner? Thats the only reason i can think it would go up so drastically. It passes everything else fine even the running emissions. Maybe bad sensor somewhere?
Any suggestions and help would be extremely helpful. I come home Thursday and have to pass it on Friday.
Old Aug 22, 2011 | 11:24 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
I had a car that failed due to the same problem. Iwas told to change the oil and it worked. Im not sure why, but it did for me. No gauruntees.
Old Aug 22, 2011 | 02:23 PM
pettyfog's Avatar
I was told the same.. back when we had Echeck around here. I had friends who did and it worked. Also drain all that gas you can and put Exxon or BP in it.
And EXERCISE that engine a few miles before you go in. "Blow the carbon out" isnt just an old timey euphemism.
Old Aug 22, 2011 | 02:28 PM
xgiovannix12's Avatar
thats good to know =P
Old Aug 22, 2011 | 05:31 PM
rriddle3's Avatar
How old is the catalytic converter? If it passes when the engine is at higher rpm and the exhaust is hotter, that would be something to suspect since the cat may not be performing optimally.
Old Aug 23, 2011 | 07:41 AM
kristoph30's Avatar
If the cat isnt performing correctly, wouldnt the 4th O2 sensor detect it and set a code? Just wondering.
Old Aug 25, 2011 | 07:22 PM
MikeRo's Avatar
Just had the oil changed, maybe 300 miles ago, when tested was running Shell V-Power gas, and drove the highway to get there, and gave it some revving in the line pre-test. No check engine lights or anything. Do you think its worth a shot to switch out an O2 sensor or two? Kinda down to last minute, looking like I'll have it for a month at school without a valid inspection....
Old Aug 25, 2011 | 09:12 PM
kristoph30's Avatar
Dont start guessing. Youre just wasting your money.
ddog800
14
Feb 16, 2011 03:01 PM
chvyblazer00
Dec 1, 2010 01:45 AM
Silver00LT
Sep 14, 2010 10:33 PM
77Nova
Aug 28, 2010 10:38 AM
paulbaby
Aug 19, 2008 08:28 PM
