Shifting problems
Old Jan 9, 2013 | 11:23 AM
Adamhon11's Avatar
Adamhon11 is on a distinguished road
Default Shifting problems
I just bought a 1999 Blazer that is slow shifting into 2nd, have to speed up to about 20-25mph and then let off the gas. The guy said it had code P0751 on it and so he tried to change the 1-2 shift solenoid but he changed the 3-4 on accident instead. I just changed the 1-2 solenoid and it did not stop the problem, any ideas? I am sorry if this has already been covered somewhere, I tried looking at previous threads.
Old Jan 9, 2013 | 03:05 PM
50lb_cat's Avatar
Does it do this when cold and warm? Have you changed the transmission filter?
Old Jan 9, 2013 | 05:28 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Smile
Try taking out the actuator piston on the side of trans and either clean or replace it..Also could be your fluid is old and needs to be changed.Also the trans issues have been flogged to death no offence to you Im just saying.
Old Jan 9, 2013 | 07:58 PM
Adamhon11's Avatar
It doesn't want to shift into 2nd when it is cold or hot. I changed the fluid and filter when I changed the solenoid.
If you know of a thread that deals with this, just let me know.
Old Jan 9, 2013 | 09:32 PM
richphotos's Avatar
Do a search, and you will find millions. ( a bit of an over exaggeration )
Old Jan 12, 2013 | 06:26 PM
Adamhon11's Avatar
Ok, so I've been searching all over the site and haven't found a thread with the same problem, maybe I'm just missing them so if you know of one please link it instead of just telling me they are out there. Or if you have any ideas on my problem I would appreciate the help.
Old Jan 13, 2013 | 12:42 AM
blown262's Avatar
blown262 is on a distinguished road
When it finally does shift, does it slam 2nd abnormally hard? I had an issue with my 97 4x4 where it would hold 1st for a decently long time and then pound second. My problem was a crack in valve body was allowing internal fluid "bleeding" killing my line pressures.
Old Jan 13, 2013 | 02:19 PM
Adamhon11's Avatar
It doesn't slam into second, I just have to let off the gas and then it shifts alright. It shifts fine with all the others gears.
Old Jan 18, 2013 | 04:23 PM
Adamhon11's Avatar
Anymore ideas? I am going to take it in to a tranny shop next week.
fiXXitup
Sep 2, 2009 12:47 AM
TylersBlazer
Jan 24, 2009 09:07 PM
jbouchard09
May 14, 2008 09:11 AM
96jimmy4x4in
Oct 7, 2007 09:23 PM
farmboy191
Jun 11, 2007 02:24 PM
