Shuddering Problem
Old Jul 23, 2012 | 09:36 PM
sidewinder's Avatar
sidewinder is on a distinguished road
Default Shuddering Problem
i just got me a 98 blazer and im having problem with it studering. when i put it in gear give it a lil gas and it studers but if i gas it no studer. the guy i got it from said it was the cat. so i took it to autozone and codes on misfire, vacum leak, and cat misfunction pop up. any ideas?
Old Jul 24, 2012 | 10:50 AM
dbshortwave's Avatar
dbshortwave is on a distinguished road
I would go with replace the intake gaskets, I wouldn't rule out the Cat, and I would do a good tune up cap, rotor, coil, plugs, and wires. check under the air box tube for a worn out PVC valve line. and replace what vacuum lines that aren't hard plastic. if you still have a misfire I would look at the ignition module on the side of the coil the pickup under the cap and last but not least the crank pickup under the engine by the harmonic balancer
BTW this isnt the spot for this type of question. Check the form over the answer would have been there and I'm no better in responding.
Old Jul 24, 2012 | 11:00 AM
*Moved to a new thread in 2nd Gen Tech* - Please be aware of the thread topic to which you are replying to and the section it is posted in; ensuring that the nature of your reply is in the scope of the topic being discussed and that it will not detract from the thread author's original concerns.
What are the specific OBD2 trouble codes (Pxxxx)?
Old Jul 24, 2012 | 12:39 PM
247monster's Avatar
like said earlier cap and rotor could be a possible issue if you are getting water inside it will cause a misfire.
simplyjessi
Jan 21, 2012 10:10 PM
missjo123
Sep 13, 2011 12:50 AM
cherokee4
May 18, 2011 01:10 AM
marsh4005
Nov 24, 2008 05:57 PM
blazergirl15
May 15, 2006 12:13 AM
