smoke coming from engine
I don't know what exactly the problem is, this happened a few days ago too and it doesn't overheat but I had the AC on but from what I can see:
The smoke is coming from down there where the arrow is pointing I'm lost as to whats causing it, other than oil i'm not sure if there's anything else important down there, and I checked that too, Oil is full. Also far left of the picture you see that big thing, that was ice cold to the point where's water all over it..Is that supposed to be like that? help is greatly appreciated...thanks guys
The "big thing" is the accumulator for the A/C. When the A/C or defroster is on, it's perfectly normal for it to frost over. It's possible that the condensation is dripping on the exhaust causing steam. Another possibility is the lower intake manifold gasket could be leaking coolant on to the exhaust manifold or exhaust crossover pipe. Is there an odor to the "smoke"? Is the coolant level in the reservoir between the min & max marks? Are you losing coolant?
There's a rubber drain hose on the bottom of the evaporator housing that allows condensation from the evaporator to drain to the ground. If it gets plugged up or routed in the wrong direction, it can drip on the exhaust. It's a real bear to see it, usually you have to get your hand in there and feel your way around.
88blazer4x4owner
Jan 8, 2012 04:23 PM
Kevin.N.Odom
15
Feb 4, 2010 11:02 PM
RomanCatholic
16
Sep 1, 2009 10:47 PM
Shaftjohnny88
Jun 4, 2005 07:58 PM
