Smoke from dipstick tube
Old Sep 1, 2023 | 02:51 PM
Jmack's Avatar
Jmack is on a distinguished road
Default Smoke from dipstick tube
1998 Blazer 4wd 4 dr
l just had my lower intake manifold gasket and my evap canister solenoid replaced at the shop. Now there is grey smoke coming out from the oil dipstick when I pull it out. Anyone know why?
Old Sep 1, 2023 | 09:46 PM
What did the oil look like? Is it possible some coolant got into the oil and is boiling off?
Old Sep 1, 2023 | 10:19 PM
LesMyer's Avatar
PCV not working
Old Sep 2, 2023 | 08:35 AM
Jmack's Avatar
The oil looks good to me. If the PCV is not working would the check engine light be on?
Old Sep 2, 2023 | 11:05 AM
Blazersaver73's Avatar
Blazersaver73 is on a distinguished road
Only if/when it detects a problem. Steam in the crankcase is released by the pcv valve, which is what you're seeing through the dipstick tube, which is connected to the crankcase, indicating a faulty pcv valve. Easy way to diagnose, pop the oil fill top off and look for excessive chocolate milk-like goo on it and the valve cover.
Old Sep 6, 2023 | 12:01 PM
LesMyer's Avatar
Purpose of the PCV is positive crankcase ventilation where blow-by getting past the rings is sucked into the intake and takes a second pass through the engine, instead of venting to the atmosphere (or leaking out the dip stick tube). If you have actual steam in your crankcase, then you have a much bigger problem.
If you have a big vacuum leak preventing proper PCV operation that could give you a lean O2 sensor code. Take it back to the shop and let them fix their screw-up.
Whisper6691
Oct 23, 2015 08:10 PM
ewarma
Oct 20, 2015 10:12 AM
g-ronimo
Jul 12, 2013 11:40 PM
talonmike
Apr 27, 2009 11:00 PM
Shaftjohnny88
Jun 4, 2005 07:58 PM
