Smoke gets in your eyes.
Old Aug 21, 2013 | 06:49 PM
ol' grouch's Avatar
ol' grouch is on a distinguished road
Default Smoke gets in your eyes.
I am having fits trying to get my '96 lined out. I fixed the coolant leak and then it started blowing fuel out the tail pipe. Rather than tie up my garage, I had other stuff waiting, I took it to a shop that I trust. The injector for #1 cylinder was spraying fuel full blast. I put the updated injectors in it and the puppy still blows smoke. It's idling at 3500 rpm and turns the neighborhood white.
The injectors have been chaged. I'm wondering if something is sending a faulty signal. Anybody got any ideas? Basically it's doing the same thing but not having the hydroilocking it had before. At least that is gone. I just can't shake the feeling something isn't connected right or there is one huge vacuum leak. I'm running and running but getting nowhere fast.
Old Aug 21, 2013 | 07:04 PM
JavierEscalonJr's Avatar
JavierEscalonJr is on a distinguished road
i'm with you on the vacuum leak maybe the plenum needed some more adjustment, i know when i changed the injectors on my 96 the plenum didn't go right the first time just something to check
good luck
Old Aug 21, 2013 | 07:59 PM
rexazz2's Avatar
spray wd40 around the plenum seems should change idle if there is a leak
Just remember it is flammable so have a garden hose or fire extinguisher handy JIK
Old Aug 22, 2013 | 06:00 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
wd40 is flammable? news to me.
Anyway white smoke is signs of coolant burning, especially enough to leave clouds. If it was rich it would be black smoke.
Old Aug 22, 2013 | 07:02 PM
ol' grouch's Avatar
Usually, coolant is the cause of white smoke. However, I've seen gasoline, when you really dump it in, like a stuck float, do the same thing. I'm suspecting the seal didn't take on the intake. That would cause both coolant and excessive vacuum.
wolfmagicsong
May 16, 2013 09:26 AM
old skool luvr
Jul 22, 2010 10:16 PM
hubert hefner
63
Mar 16, 2010 11:29 PM
nai0013
Jul 26, 2008 08:31 PM
jimbosv650
Feb 26, 2008 07:02 AM
