smoking for vacuum leak
Old Jul 15, 2012 | 05:56 AM
ncpatsfan's Avatar
ncpatsfan is an unknown quantity at this point
Default smoking for vacuum leak
Blazer 2001 4WD 4.3L. In trying to track down the cause of my lean codes P0171, P0174 I smoked my intake manifold through the brake booster line. I left all connected except the MAF and plugged the rubber boot that goes to the back of the MAF. The majority of the smoke I saw was coming out from what appears to be the timing chain cover. I confirmed this with some soapy water. With or without the breather tube and PVC hole plugged this happens. Any idea if this should happen? Could this be a sign of a leaking intake manifold gasket inside the engine rather than external? If I pull the oil dipstick I will get smoke there as well. I had a little bit of smoke came out the throttle body shaft and some from around where hood seals to the throttle body otherwise. Before I go an do an intake manifold gasket I want to be sure this should not occur. I have no issue with loss of coolant, and can not find and external intake manifold leaks via smoke or carb cleaner.
NOs
Jan 22, 2010 12:47 PM
DucatiKoenig
Nov 1, 2009 10:57 PM
roberfell
Oct 27, 2007 07:51 PM
FemmeVamp
Aug 29, 2007 12:13 PM
MsRandi
Mar 10, 2007 03:52 PM
