solution to what is thought be bad spider injection or fuel pump
Old 06-12-2009, 01:32 AM
97lsblaza's Avatar
97lsblaza is on a distinguished road
Post solution to what is thought be bad spider injection or fuel pump
I have a 97 2door 4wd blazer w/ 210,000 miles on it. I was having problems with what was thought to be the spider injection or the fuel pump. my blazer would bog at certain rpms and i could only give it quarter throttle. this may not work anytime, but what fixed mine was a bigger fuel filter, turn the fuel pump voltage to 12v and put a bigger fuel line on it. it even fixed the whine i got from the fuel pump. now it runs great, you would never guess it had over 200,000 miles. hope this helps!
Old 06-12-2009, 09:19 PM
What do you mean by "turn the fuel pump voltage to 12V"? System voltage with the engine running should be somewhere around 14V...
Sounds like you had a restriction in the fuel line...
StarBlazing
10-26-2014 08:35 PM
Mlozoya
07-28-2013 11:47 PM
nineteensixtycaddy
04-16-2010 07:27 AM
SlydinClyde
10-20-2009 12:56 AM
mikemp6
10-29-2006 09:58 AM
Quick Reply: solution to what is thought be bad spider injection or fuel pump
