Spare Tire Mount on 4 door?
Old Apr 27, 2010 | 10:06 PM
crazycaptain56's Avatar
crazycaptain56 is on a distinguished road
Default Spare Tire Mount on 4 door?
Can you put one on a 4 dr?
Old Apr 27, 2010 | 11:33 PM
BlazerGuy2001's Avatar
Ive never seen it done but i would imagine it is possible with the proper holes and some reinforcement to the sheet metal. Otherwise i dont see why not
Old Apr 28, 2010 | 10:00 PM
4x4blazerguy's Avatar
I'm sure you can. But the cost of the carrier might not be cheap.
Old Apr 28, 2010 | 11:13 PM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
Absolutely. I can't find the link, but there was a guy who took his 4 Door and Mounted one to it, also cut part of the back off to make it like a avalanche. Its definitely possible, not sure on the difficulty.
Old Apr 29, 2010 | 09:02 PM
I think if you can find a carrier off a 2 door, it would bolt right on I believe. As far as beefing up the mounting areas a person could use plating inside the panels of the body. I think the cost would be in finding a carrier. The rest is just good ole fabrication.
Old Apr 29, 2010 | 09:55 PM
im not sure it would just bolt right up, i believe the two doors have more of a curve to the back that would prevent it from bolting right up...i read that somewhere but i could be wrong
Old May 17, 2011 | 10:14 AM
Tschudy 95's Avatar
Tschudy 95 is on a distinguished road
so you think i should find a two door and take the rack and the door..
because im gonna need to change the door too right..
Old May 17, 2011 | 02:34 PM
warthogdriver's Avatar
i know someone who has done it...hint hint check the sig pic...
and the how to goodness
https://blazerforum.com/forum/tech-a...-4-door-48923/
any questions feel free to ask away...
Old May 17, 2011 | 05:08 PM
Benedict1337's Avatar
yea its really not hard just make sure you measure a million times before you do it
Old May 18, 2011 | 04:07 PM
step66's Avatar
If you look real closely,the only angle differance between the 2 & 4 door is in the slant of the glass,not the rear quarter! The big issue I see is, as has been mentioned,The re-inforcement! These WERE added at dealers using GM blind-nut fasteners (basically an old Dorman type style of freeze plug) one must drill fairly large holes to accomodate the blind-nut however(1/2-5/8") so one needs to be careful! I have had the spare on my rear floor now for years (safely secured) and have looked in to all possibilities,including the interior set-up. Any ideas...
