Spare Tire Won't Come Out!
Old Nov 27, 2007 | 03:57 PM
FemmeVamp's Avatar
FemmeVamp is an unknown quantity at this point
Default Spare Tire Won't Come Out!
Ok, I've got a 1997 Blazer...today I ran over a bolt in the road & my tire is a goner...my spare is located under the back rear of the Blazer. My husband got the initial piece that holds it on off, but the tire still won't come off. Any ideas what the problem is?
Old Nov 27, 2007 | 04:23 PM
bobc997615's Avatar
bobc997615 is an unknown quantity at this point
Default RE: Spare Tire Won't Come Out!
My 2001 has a crank downwinch that you access thru the rear bumper. Use the jack handle to lower the tire down. It's mounted on the cable with a spring loaded "tee" to hold it up underneath.
Old Nov 27, 2007 | 05:49 PM
blzR's Avatar
blzR is an unknown quantity at this point
If you mean you 'got tire lowered onto the ground' but still can't get it off..you have to kind of lift that oval piece (holds the tire tight to the vechile)and lift it slightly upwards,so the oval sectioncan be narrowed.
Old Nov 27, 2007 | 11:15 PM
FemmeVamp's Avatar
Correction: He did NOT get the piece off that's holding it on...I only thought he did. He said that it just kept turning and turning....
Old Nov 28, 2007 | 05:43 PM
blzR's Avatar
What part keeps turning&turning?Do you mean:little fitting where the jack end fits into(on outside of lowerbumper)?
Has he tried putting weight & pulling down on tire>then tried to unwind it some.
Old Nov 29, 2007 | 11:07 AM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
It is possible that the spare tire is "frozen" up under the vehicle. My wife's van had a flat, I got there to change it and could not get the spare to drop out of the vehicle (the cable and carrier were laid out under the van on the road). I ended up sliding a 2x4 between the spare and the underside of the van and popped it loose. What a PITA!
Old Nov 30, 2007 | 02:09 AM
blzR's Avatar
Possible that a part of the cable thatunravels isfroze/rusted/stuck, and has knotted itself from trying to lower it from the removal attempt,& now binded?
Old Nov 30, 2007 | 07:23 AM
classic_cruiser's Avatar
classic_cruiser is an unknown quantity at this point
Yeah I did the same thing when I first tried to take off the spare... the spare is NOT removed by spinning the metal bar that's in the center hole on the spare tire. You uneed to stick the flat end of the tire iron in the little round hole next to the license plate, and turn counter-clockwise. The tire will slowly lower to the ground unless, like someone said earlier, the cable is binding inside the tube that holds it.
Being new to blazers, I should have read the manual... my spare tirelowering cable came unravelled by trying to remove the spare by attempting to turn the metal bar inside the center of the spare tire, thinking it was like my other car!
Old Nov 30, 2007 | 11:54 AM
blzR's Avatar
I hope Femme did'nt get all stuck & binded it that mess too!
sunshine666466
Aug 8, 2014 12:04 AM
49er_Dirtbag
Jan 14, 2010 06:43 PM
03BlazerLS
Nov 26, 2009 02:40 PM
Lower_Level
Oct 20, 2009 10:19 PM
