Spark advance 30*
Old Jan 5, 2018 | 10:14 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Originally Posted by Captain Hook
Hi Les, I've never tried it that way, I suppose it's worth a try though. I always command the IAC as low as it will go, and then adjust idle rpm to ~350, (TPS should end up at .5 volts or less). I have always had good results doing it that way. Rule of thumb is, when you command the IAC all the way down, the engine should not stall, but close (usually around 300rpm it will stall). The idea is to keep the throttle blade open just enough so that it doesn't stick in the bore at idle. And that's assuming the throttle blade and bore are clean... on the underside too
& just like that, The Captain was back......
JCBLAZER96
Nov 26, 2015 07:23 PM
monette999
Jun 11, 2015 01:53 PM
Doctorvette
Nov 5, 2012 11:57 PM
kevinph
May 1, 2011 08:44 AM
silvers10
Apr 21, 2008 01:02 AM
