Speedo working on and off
Hi,
My 2000 ZR2 5-speed is running hot and cold. I bought the truck two months ago and it must have been sitting for a while, my mechanic mentioned because rust collected on the underside. I have 31" tires all around and I bought it like that. At first the gas gauge and speedometer were not functioning. The most dangerous part is on the highway where the speedo shows 30-35 MPH when I am going at least 55-60 MPH. I drove it around maybe 100 miles and I topped it out at that time (98MPH I guess) and the Speedo started working again. It worked fine until I brought the car to the garage at which point I got a tune-up, coolant flush, oil change, new shocks, new pitman arm, and serpentine belt. Now it went back to showing 35 when I am going 60. Can it be the VSS?
Just as a side note I have introduced Chevron Techron into the gas like Swartlkk had previously said to do to try to salvage the gas gauge sensor and it has shown a difference from only one application. I will keep doing that every time i fill up until it is as correct as I could get it.
Speedometer Round 2
Hello everyone. I have a 2000 Blazer ZR2 5 speed..
I posted earlier about a problem with the speedo having mood swings, working when it feels like it. It is now officially showing only half the speed that I am going.
I live in NYC and the speed limit is 50 mph. I go 60 mph on the highway to and fro work and the speedo shows 30-35 mph steady. I know I am going 55-60 because everyone else on the highway can't be going 30 mph. What do I need to replace? This is my first non-hooptie vehicle and I wax her myself. I intend on keeping her for as long as I am in school (8+ yrs) so I definitely want her at her best.
Thanks everyone!
Thanks everyone!
*Combining your two threads* - It is permissible to bump a thread if you have not received a response after a reasonable period of time (>24hrs).
Check your VSS sensor connections. Remove the VSS sensor and clean it. The VSS sensor is located at the tail housing on the back of the transfer case.
michaelmoodyblazer
07-24-2012 08:52 PM
mattkc
20
07-09-2011 12:14 PM
