speedometer, odometer and cruise control
none of them working, any help? fuse?
Anyone?
"What functions depend directly on the VSS signal, Alex..."
What unusual happened just before? Either VSS sensor or wire to
Nothing unusual happen before, bought it this way
Well, ohmmeter and the above chart will give you a start.
OK, thanks Petty, you`ve been a big help with stuff here
I know my 1st gen has a fuse for the cluster. It blew and only my speedometer and tac wasn't working. everything else was. On mine its a 20 amp fuse,I dont remember what it was labeled as. Check all you're fuses before digging into it.
Chris, easiest rt first, always. Thanks
on a 98 if it has a digital dash it will be fuse #3 on the driver side fuse panel inside the door jam. For what its worth pull the fuse and see if your gauges work. I know it sounds strange but mine did the same thing and I just pulled that fuse and all my gauges worked again. At the sacrifice of cruise control of course.
Pulled the number 3 fuse, no change
