speedometer reading 0
Old Oct 2, 2010 | 09:07 AM
fixmycar's Avatar
fixmycar is on a distinguished road
Default speedometer reading 0
Sons 96 blazer shifting improperly and speedometer reading 0mph.shifted to 4wd and back to 2wd and everything was ok . but had problems again next day and he tried same thing and it worked also. I suspect faulty or loose connections/sensor .I will go look at vss that Swartlkk has recommended in other posts.Am I on the right track ? if not please educate me on what I should look for thanks ps. may or may not be related abs light came on 2months ago(still on)cleaned sensors at wheel no help
Old Oct 2, 2010 | 12:58 PM
Sounds like the VSS sensor. Could definitely be related to the ABS light. You'd need to get the codes read to know for sure.
Old Oct 2, 2010 | 05:38 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
I just had this happened to my blazer to its definatly your vehicle speed sencor on the tail shaft of the transmission or transfur case . My part number from advance is s8310 , and costs about 50 bucks . But better than rebuilding the transmission again . I say that because my boss and I just rebuilt the tranny and it was my first total tranny rebuild . the transmission works awesome now .
Old Oct 3, 2010 | 11:49 AM
fixmycar's Avatar
thanks for info / cleaned sensor yesterday and will wait for next occurrence . when I had it out i measure resistance @ 1.6 k ohms (1600).............. he just walked in and says it is screwed up again. I guess I will go buy one . I will measure new one's resistance and post its value for next person. unless somebody posts it here first
Old Oct 7, 2010 | 08:12 PM
fixmycar's Avatar
since i measured 1600 ohms i thought sensor was ok so I checked wiring @vcm and didnt read the 1600 .So I check the wiring which turn out to be ok recheck sensor and it was open. Went to advance cost $56 (new measured 1250 ohms) put it in an it ran ok . reset p0502 to clear check engine light . ABS light still on though I am hoping it clears after miles or cycles . I saw on other posts people asking what wrench to use on VSS mine I used a 1 inch crows foot. Thanks to all the help and excellent info in Swartllk P0502 explained .
Old Nov 12, 2011 | 04:35 PM
nicks99's Avatar
nicks99 is on a distinguished road
havn same problem, changed vss still no speedo and not shifting right any thoughts?
kenjkun
Mar 14, 2010 03:36 AM
FImports
14
Dec 4, 2006 10:46 PM
DaShark
May 16, 2006 06:13 PM
ivannj
Jan 13, 2006 11:47 PM
thanser
Dec 11, 2005 11:41 PM
