Speedometer reading fast
A dealer might be able to reprogram the computer (ECU or BCM) so that it is calibrated correctly. I was looking at an OBD reader that I think, if I read the specs correctly, could do this too. (https://www.videntstore.com/wholesal...scan-tool.html)
I think it's fairly common for speedometers to read a little bit fast. Maybe not that much, though. Personally, I would probably "correct" the problem by replacing the tires (when they're worn) with the next size bigger. You might also find some that are the same size but actually measure larger. Check out the specs for revolutions per mile. Most tire manufacturers provide this.
That's odd, for sure. If you have a scanner, maybe check the speed sensor output to see if it matches the gauge? Could be that the speedometer itself is not reading accurately. Just a WAG, though.
moldeck
Tires and Wheels
03-02-2010 07:03 AM
