Spider Injecter?
Old Jun 25, 2014 | 03:39 PM
  #51
Unless you can actually see the leak, it can get tricky isolating each part in the plenum to locate it. If the upgrade hasn't been done, you'll thank yourself for doing it Better performance, better mileage, instantly. The upgrade is plug & play, no programming necessary. Make sure the bracket that secures the metering block in place comes with the kit, the original bracket will not fit properly on the upgrade.
Old Jun 28, 2014 | 09:36 PM
  #52
v8vette84's Avatar
v8vette84 is on a distinguished road
Well I replaced the spider today. I could see that the OEM spider was leaking out of the FPR. Behind the spider the intake was nice and shiny, not all black like the rest of the intake. So it does start easier now and consistently but it still is taking a tad too long to fire up. I'm going to attack the cap/rotor, plugs, wires tomorrow to see if it will help. I'm not sure if the plugs have ever been changed..... :/ The new spider definitely helped smooth out the idle and revving. Sounds different when revving too. It runs good once it starts! But the new spider definitely helped the starting problem. Now when it starts it comes to life "weak".. I have no idea how else to explain it. I guess the best comparison could be starting a car that was flooded or had weak spark. Hopefully I have some plugs that are trash and it will start easier.
Old Jun 28, 2014 | 10:40 PM
  #53
newguy's Avatar
ac delco plugs cap and rotor
Old Jun 28, 2014 | 11:12 PM
  #54
v8vette84's Avatar
That is the plan! Already ordered Delco stuff!
Old Jun 29, 2014 | 06:06 PM
  #55
v8vette84's Avatar
Well I haven't changed the cap/rotor/plugs or wires yet but today it started right up like it should. I'm going to try a few more days to see if it stays better. I will still do the tune up stuff but I'm just curious to see if its better now.
Old Nov 2, 2014 | 11:07 PM
  #56
bo jonson's Avatar
bo jonson is on a distinguished road
Just a thought; if the FPR is 'downstream' of the points of fuel pressure measurement (filter outlet & service port) could the FPR/vacuum be an issue?
Old May 27, 2015 | 09:38 AM
  #57
mickey_bigdaddy's Avatar
mickey_bigdaddy is on a distinguished road
Any final comments?
From what I can tell, it WASN'T a fuel pump issue. Correct?
hunter05
35
May 16, 2024 09:01 PM
hunter05
Mar 29, 2014 11:32 AM
dougg01
Feb 6, 2010 05:16 PM
wythel
Aug 9, 2006 02:10 AM
PhatKat
Engine & Internal
May 29, 2006 10:35 PM
