Spliter
Old Nov 13, 2013 | 01:27 PM
spliter's Avatar
spliter is on a distinguished road
Default Spliter
After attempting to get my 2000 blazer to shift from 4 high to 2 high three or four times it locked in 4 low and won't come out can anyone tell me if there's anyway to go back to 2 high.
Old Nov 13, 2013 | 05:12 PM
Welcome to the forum! Does the switch on the dash have 3 buttons or 4 buttons? Have you tried disconnecting the battery negative cable for 5 minutes and re-connecting? This will force the TCCM, (Transfer Case Control Module) to reset.
Old Nov 13, 2013 | 06:22 PM
spliter's Avatar
Thanks for the reply,my blazer has the 3 button on dash and I have disconnected the battery but I took positive and negative cables off does this do the same as just the negative off.
Old Nov 13, 2013 | 06:30 PM
Yup, does the same thing, good job. I assume that made no difference.
Do the lights on the switch blink when you turn the ignition to ON, without starting the engine? If so, how many times do they it blink?
Have you removed the TCCM, and the connector from the TCCM, and checked the terminals in the connector? Sometimes they don't stay seated all the way in the connector. They also have a habbit of collecting corrosion, which needs to be cleaned off. If this prooves not to be the problem, check the connector & terminals at the encoder motor on the driver side of the transfer case.
Old Nov 13, 2013 | 06:40 PM
spliter's Avatar
There are no lights flash, the only time I have lights is when I push the 4 high or 4 low then both 4h & 4L lights are on.
Old Nov 13, 2013 | 07:41 PM
OK. Check the electrical things that I mentioned above, and post your findings.
Old Nov 14, 2013 | 12:34 AM
spliter's Avatar
Not sure were the TCCM is or the encoder, can u help me with this?
Old Nov 14, 2013 | 03:22 PM
TCCM is behind the passenger side kick panel. Encoder motor is located on the driver side of the transfer case.
Old Nov 14, 2013 | 10:42 PM
spliter's Avatar
Thanks Captain Hook, I will check connections and let you know what happens,also do you know if I can take shift motor off and manually shift it back to 2HI so I can drive it.
Old Nov 15, 2013 | 10:15 AM
LannyL81's Avatar
Yes you can remove the encoder motor and manually shift it back to 2HI...I jsut do not remember which way to tell you to turn it. Although I guess it would either go to 2HI or 4LO.
There have been threads on here regarding this...perhaps do a search for encoder motor and see what turns-up.
Good luck with it.
