spray to run
Old Sep 11, 2011 | 07:25 PM
branhed's Avatar
branhed is on a distinguished road
Question spray to run
new to forum, i have a 96 blazer that I can spray one quick shot of carb cleaner to get it running, replaced gas,air filter,pcv. Remove and cleaned throttle body, still will not start on its own. Any ideas....Thanks
Old Sep 11, 2011 | 08:23 PM
TheRandom1's Avatar
Does it stay running once you get it running via carb cleaner?
What do you mean you replaced gas? Any codes popping up on your dash? Any symptoms when it runs? (i.e. running rough, no power, etc)
Old Sep 11, 2011 | 09:13 PM
branhed's Avatar
replaced gas filter, and yes it runs normal after quick squirt of carb cleaner no codes
Old Sep 11, 2011 | 09:17 PM
What is your fuel pressure? Have you done a pressure & leak down test (details can be found by clicking on the link found in the lower right of my signature below)? If you haven't done a fuel pressure & leak down test, please do so and report the specific pressure & leak down rate you observed.
From the sounds of things, you have a fuel system problem.
m3dragon
Feb 24, 2015 10:04 AM
davtak
Jan 10, 2007 04:33 PM
jacsdad
Apr 20, 2006 02:00 PM
V6 Vortec Jimmy
Sep 14, 2005 11:50 PM
m00nwater
Aug 2, 2005 01:20 AM
