Squeak/grind when parked
I have had this very strange noise for about 6 months now and was just able to find out the area it is coming from.
When I put the truck in park and shut it off I would hear a grind/squeak as the truck rolled forward or back with the amount of play found in an automatic transmission when in park. I have been able to pinpoint the noise coming from the rear right tire area. If I go to that tire while in park, engine off, and roll the truck forward and back slowly I can recreate the sound. I have no idea what is causing it.
I removed the tire and can not recreate it with the tire removed. I will have to try again but I wonder if when the truck is jacked up it relieves the pressure from what ever is causing the noise.
I just removed my caliper bracket and pins and regreased them. Still no luck.
Any ideas?
Any ideas?
ORIGINAL: bobbyj42
I have the exact same problem except mine is in the left front wheel. I have a 2001 2WD.
WickedBlazer
Sep 12, 2012 03:14 AM
abig84
Jun 20, 2011 08:41 PM
1996blazer1
Jan 24, 2010 03:36 PM
