squeaking comes and goes
This week, I have notice that I was having quiet squealing. Yesterday, I have noticed it again too, but went away. This evening it came back louder than ever, I could now seem to hear it coming from the right front wheel. It reminded me of a low brake pad indicator, but happened while I was driving it still when I braked. It them went away again. 2003 Chevy Blazer 107450 miles. I do know the brakes are running low, but never gave any noise indication. Could it be the brakes or something else>
Could be wheel; bearings also. they will often have an intermittent sound when they start to go bad. Pull the wheel off, disconnect the caliper and see if you can move the rotor assemble in and out and side to side. If it moves in any direction other than spinning chances are the bearings are worn out.
I had put new tires on in Oct. They had checked the stuff out, they found my right side lower ball joint and idler arm was bad, but nothing was said about the wheel bearings. However, I doubt they took the caliber off like Greegg64 said to do. Also, anything I read on the web, I don't see anyone mentioning that wheel bearings making a squeaking sound, mostly low rumbling sounds.
Skitzoape
07-03-2012 05:46 PM
MissTina0301
12-18-2010 03:17 PM
Seabbatical
07-11-2009 02:30 AM
blaze1925
09-20-2005 11:54 PM
