squeaky Blazer
Old Apr 8, 2008 | 07:11 PM
03blazer's Avatar
03blazer is an unknown quantity at this point
Default squeaky Blazer
Whenever i start moving before i hit about 15 to 20 mph my blazer makes this loud squeaky noise, i thought the shock bushing were dry rotted so i sprayed them with some wd-40 but that didnt work. Any suggestionS? im going to take it to my buddys shop and put it on a hoist, just wondering if anyone has any tips b4 i replace everything. Thanks!
Old Apr 8, 2008 | 08:28 PM
TripleBlackBlazer's Avatar
Default RE: squeaky Blazer
Is it a constant squeak, more of a squeal almost? If so I would check your squealers on your brakes.
On another note, I had squeaks in my front end that seemed to be only around low speeds, but that was only because that was the only time I was going slow enough to hear them. Anything above the 15-20mph that you mentioned and the road noise was enough to overpower the squeaks. I just recently sprayed my control arm bushings and sway bar bushings with some silicone lithium spray and my squeaks went away.
tgod's Avatar
tgod is an unknown quantity at this point
I greased my lower ball joints and my squeak went any. Grease all your zerk fittings.
Old Apr 9, 2008 | 03:27 PM
03blazer's Avatar
i greased all my fitting yesterday and the squeak was still there, Where are the squealers on my brakes?
lizardking88mph
Oct 30, 2011 08:50 PM
tonedef132
Nov 4, 2009 07:20 PM
Peaches
Jun 26, 2008 10:26 AM
Kaffeene
Jun 21, 2008 11:34 AM
sprint777
Apr 6, 2006 06:18 PM
