Stalls at op temp, no start until cools down.
Old Oct 14, 2019 | 08:59 PM
B Rad's Avatar
B Rad is on a distinguished road
Unhappy Stalls at op temp, no start until cools down.
Noticed air in the fuel line at the test port the last time it stalled. Attached a pressure gauge and it started right up without cooling down and continued to run fine as long as the gauge was connected. Returned to the same problem after removing the gauge. Totally stumped, no problems at all as long as the gauge is connected... I left it connected for 3 days, the problem came back when I took it off. No trouble codes at all ??? Typical pressure readings. I went the whole 9 yards as far as checking all the sensors and wiring before I posted this and thought I'd ask before I replace the pump. (new OEM pump 2 years ago)
Old Oct 14, 2019 | 09:56 PM
odat's Avatar
check the scharder valve - even tho its on the pressure side it maybe leaking and sucking air - been there seen that .....
Old Oct 17, 2019 | 05:01 AM
B Rad's Avatar
Pulled the pump and it turns out the Venturi tube was plugged so it wasn't keeping the bucket full when it was below a 1/4 tank causing it to draw air into the fuel line. Like a vapor lock. New one on me, bonus for figuring it out myself without any help from the forum 😲
Old Oct 17, 2019 | 11:43 AM
odat's Avatar
Glad you got it figured out - thanks for the check back and good luck .....
excalibur01
Apr 16, 2011 01:07 PM
hilsenteger
Oct 8, 2010 09:30 PM
blazin_j
Mar 6, 2010 11:12 PM
nj4x4blaze
Aug 9, 2009 10:18 AM
intheweeds
Jul 18, 2009 06:48 PM
