STARTER PROBLEM??
Old Apr 18, 2008 | 02:55 PM
EASTBAYBLAZER's Avatar
EASTBAYBLAZER is an unknown quantity at this point
Default STARTER PROBLEM??
ok so now it wont start its a 95, sounds like the starter, it just keeps clicking so i d/c the battery for the night go back out again connect iut back up and it still makes the clicking soud, is this a bad starter?
edit* the battery is good
Old Apr 18, 2008 | 03:15 PM
rriddle3's Avatar
Default RE: STARTER PROBLEM??
Good chance of it, but have you double-checked all the wiring connections at the battery andat the starter?
Old Apr 18, 2008 | 05:28 PM
where is the starter on a 95? wiring looks fine
just went out to clean the terminals they was still disconnected , had some corrosion on the positive , used sandpaper to get it off, got it all off plugged it back in and started clicking again very slowly then i seen a bright spark down below the engine as soon as i connected the battery, disconnected the negative and the spark stopped, checked the battery and it is dead now
Old May 10, 2008 | 02:31 AM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
It's been a couple of weeks since you posted, but I'm just now seeing this. In case you still need help, I just did this a couple of months ago on my '96, and it only took an hour.
The starter is right behind the front right wheel. It's held on by two long bolts that go in from the bottom up. Someone else posted a pic of it somewhere, so you'll have to search for it.
The quick version of the replacement: [ul][*]UNPLUG THE BATTERY. The starter gives high voltage, so not doing this could kill you.[*]Remove the front passenger wheel. Make sure you use jackstands! Not doing this could also kill you.[*]Remove the wheel well cover if necessary (I just cut a little hole in it to give better access).[*]Remove the two battery connections from the starter.[*]Go under the wheel well and unbolt the two bolts.[*]Slip the starter out of the hole where it connects to the flywheel. You may have to rotate it a few different ways to get it out, but patience is the key.[/ul]Installation is the reverse of removal. Hope this helps!
P.S. A bad starter can drain your battery. This also happened to me, so I ended up replacing both at about the same time.
jdmmario
Oct 25, 2014 06:25 PM
mafiaboy01
Oct 3, 2009 10:52 PM
GMdesigner
Jun 22, 2007 12:02 PM
brownee
Jan 11, 2006 12:03 PM
gntlhwkj
Jan 10, 2006 02:16 PM
