starters in general
Old Jul 17, 2008 | 07:23 AM
kpmink's Avatar
kpmink is an unknown quantity at this point
Default starters in general
This is a general starter question. I took my starter out and when I went to put it back I couldn't find the little spacer. So I put it back in anyway hoping itd still work. I went to start the engine and got a loud grinding whining noise. Im thinking it is the starter because I didn't put the little spacer in. Is that little piece of metal that important??
Keith
Old Jul 17, 2008 | 07:35 AM
Default RE: starters in general
Yes, it is that important. You hear grinding because the gears are no longer aligned properly, causing the starter gear to hang up on the ring gear. The spacer allows the starter gear to mesh properly into the ring gear and, in turn, spin over the motor.
Your favorite parts store should have a starter shim pack for your vehicle. Problem is, you may have some trial and error in figuring out exactly how thick of a shim you need.
95BlackGA
Nov 17, 2011 10:55 PM
vetteandblazerman
Sep 15, 2011 11:48 AM
scanlojs
Nov 3, 2010 01:59 PM
donnieb83
Jul 15, 2008 07:41 PM
mbnorton
Jul 22, 2006 07:50 AM
