Starting issues
Starting issues
Ok, I have been through the post here but have not seen something related to the problem I have. I changed the starter on my 95 and I went to start it after. It was cranking but not turning over. After like two or three attempts to start it, I notice a cloud of smoke and a burn smell coming from the driver side front quarter panel. But when I looked to see if I can see any burned wiring, I saw nothing. Can anyone help me with this or has anyone experienced this? Now when I try to start it, nothing happens. No noise what so ever.
Guest
Posts: n/a
The fusable links are over there. You may have shorted the trigger wire somehow. Maybe insulation is warn. It's the small wire you put on, I know its tight over there so I extended mine to make it a little easier to work with at the starter. The links look like wires with with thick shrink tube on them.
cgrett
11-15-2010 09:08 PM
Sprocket
03-20-2008 09:39 PM
dragonsdeath
10-07-2006 01:08 AM
