Starting problems - 96 Blazer
Old Jan 8, 2009 | 08:43 AM
bruno09's Avatar
bruno09 is an unknown quantity at this point
Default Starting problems - 96 Blazer
I have a 1996 Blazer. We have been having starting problems for the last several months. Originally it would just hard start especially if it was cold. Then it moved on to it wouldn't start unless you used starter fluid. Now it will start with starter fluid but the moment you step on the gas it dies.
We have replaced the spider injector system, TPS, IAC, Fuel Filter, Trottle body assembly, catalytic converter and cleaned the MAF. Don't know what else to try. We did find a vacuum tube coming off the fuel pressure regulator nipple that is not connected to anything. Don't know where it should be connected to. Other than that - I am out of ideas.
Love my Blazer but this is getting very fustrating. Any help would be appreciated.
Old Jan 8, 2009 | 09:12 AM
rriddle3's Avatar
Default RE: Starting problems - 96 Blazer
Next step would be to do a fuel pressure test and report the results.
cgrett
Nov 15, 2010 09:08 PM
Bootyjones
Feb 9, 2010 06:09 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Dean S
Jan 30, 2006 02:51 AM
