Starting Problems in my 95
Old Nov 3, 2012 | 05:12 PM
Carrie Gutheil's Avatar
Carrie Gutheil is on a distinguished road
Default Starting Problems in my 95
I have a 95 and it usually takes about 8 seconds before it finally starts. I have replaced the fuel pump and fuel filter and no difference. We are stuck with this issue. Any suggestions would help tremendously.
Old Nov 3, 2012 | 05:19 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Does it crank slow? whats the battery voltage before you start it?
Old Nov 3, 2012 | 06:34 PM
trobbins's Avatar
when you go to start it next try just turning the key onto acc first for like 30sec an then turn it back off then try starting it as you normally would had the same problem with mine for a very long time and could never figure it out and then i went an unbolted the wires that connect to the starter an bolted back up an now have not had a problem for months now
Old Nov 3, 2012 | 08:37 PM
It cranks over normally but it still takes 8 seconds before it actually starts. We have replaced the starter about 6 months ago. I am going to try turning to acc then starting it. I will let you know the results.
Old Nov 3, 2012 | 08:53 PM
That was due to a voltage drop at the wires.
cgrett
Nov 15, 2010 09:08 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Dean S
Jan 30, 2006 02:51 AM
smplgrn
13
Jan 23, 2006 09:02 PM
