Starts then shuts off
Old Sep 24, 2012 | 09:07 PM
burned's Avatar
burned is on a distinguished road
Default Starts then shuts off
Hi, me again.
Have one I cant figure out. I was driving to work this morning and my truck died. Started right back up and made it to work. On the way home I got a few miles then it dies again. This time I got it towed home.
I have 60 psi KOEO and it holds. Drops down to 52 when running then back up to 60 psi when it stalls. I have changed the fuel filter and MAP, and pulled an O2 before the cat. Thought maybe it was plugged. It will always start but wont last for long. No check engine codes. When I was driving around last night I had the computer hooked up and everything looked good. Fuel trims were below 8%. So I cant see it being a vacuum leak.
It also has a brand new AC Delco ignition switch.
Old Sep 24, 2012 | 11:46 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
It sounds to me like the ignition switch. This happened to me a couple times and it turned out to be the ignition switch. But my truck only died when i was going about 15 mph or less maybe just coincidence but it always started right back up. unfortunately its kind of hard to find out for sure tho. 97 does have a bad rep for ignition switches.
Old Sep 24, 2012 | 11:55 PM
xgiovannix12's Avatar
DO you notice any weird things when she stalls ? Like no dash lights or the motor cranks and cranks till the dash lights back up ?
Old Sep 25, 2012 | 08:57 AM
burned's Avatar
It fires up like normally. I really cant see it being the switch. Its a new AC Delco that is around 3 weeks old. There is no way the contacts are bad already. Beside its not doing what it did when the switch went before.
Knowing my luck I think my fuel pump is not putting out the volume it should.
Thanks for the ideas though.
Old Sep 25, 2012 | 08:59 AM
burned's Avatar
No nothing like that.
Old Sep 25, 2012 | 09:41 AM
spittybays
Guest
Posts: n/a
Hey Burned, I had a similar issue shortly after replacement of ignition switch. I got back under and unbolted the harness connector block put some dielectric grease in and slapped it back together. I was lucky no problems since also the trouble was not the same as when the switch failed.
If your like me you kind of put that stuff on every thing. The wire from the coil to the cap on mine is a bit tough to get to and with the grease it kind of slipped from the cap. You might want to check if thats in there good. It caused a stall issue for me a couple of times that was hard to track. Also make sure you have 12v to the coil, key on. Good luck!
Old Oct 7, 2012 | 12:34 PM
burned's Avatar
I have re checked the ignition switch and see no problems with it. As far as I remember I had no more problems after I had replaced it.
I have been thinking about when this problem arose, and I remember it happening after we replaced the heads.
Symptoms:
Starter would not engage one day, till after a few tries (starter is 1 year old BTW)
Engine would randomly shut off
Starts back up but varies how long it stays running.
So I am wondering about the grounds at the back of the heads. As far as I know there are two aren't there? And what are they for?
I am not sure because I had a friend helping me who was undoing the stuff at the back of the heads.
Old Oct 7, 2012 | 05:01 PM
burned's Avatar
I think I got it.
The red wire from the ignition to the starter was corroded. It snapped off when I touched it, so I put a new ring terminal on the wire.
Then while fishing around at the back of the heads while cursing GM engineers, I found 2 ring terminal connectors on the drivers side just hanging there. My friend and I forgot to connect them back up, lol. For now I wrapped a wire around the ring terminals and connected it to the EGR hose bolt on the intake manifold for a ground.
Hopefully that's it!
cooljeep
Oct 7, 2012 08:37 AM
arabian49
May 7, 2010 03:02 PM
chronic1
Jan 27, 2010 08:41 AM
dachiphunter
Aug 4, 2009 05:16 AM
rogggg1020
Oct 22, 2008 09:15 PM
