stereo display wont go out..draining my batt
Old 02-06-2009, 06:53 PM
amp88fan's Avatar
amp88fan is an unknown quantity at this point
Default stereo display wont go out..draining my batt
kinda slef explanatory...was fine one day..i parked it cause of snow/ice storm we got..it sat about a week...i went down to leave the other day and it was dead...so i jumped it with my other car and left...i noticed that when i got out the clock display on the raideo stayed on...it started fine a couple hrs later but the next morn it was dead again...i disconected the battery for a min and reconected it...am i missing something simple here?
Old 02-06-2009, 07:14 PM
JOKER is an unknown quantity at this point
Default RE: stereo display wont go out..draining my batt
ONE WIRE SHOULD POWER LIGHTS
AND ONE FOR MEMORY
MEMORY WIRE IS HOT ALL THE TIME
AND LIGHTS SHOULD WORK OFF OF KEY
Old 02-06-2009, 07:21 PM
amp88fan's Avatar
ORIGINAL: JOKER
AND ONE FOR MEMORY
stock radio and has never been out before...could something have went bad in the radio to cause this?
Old 02-06-2009, 07:29 PM
IT MIGHT HAVE BUT I BET SOMETHING ELSE
IS ON MAKE SHURE DOME LIGHT IS SHUTING OFF MINE DID THE SOME THING
AND IT WAS THE SWITCH IN THE DASH AND DOOR BROKE OFF
AND LIGHTS STAYED ON
Old 02-06-2009, 08:08 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Yes, I have seen this exact problem caused by an internal radio failure. You can try discharging all of the truck's capacitors (including the ones inside your radio) by disconnecting both of your battery terminals, then touch and hold them together (positive cable bolt to the negative cable bolt) for about 30-45seconds. Then reconnect them to the battery. This works sometimes,other times it doesn't, but it's worth a try. Repost and let us know.
svd85
09-16-2009 11:56 PM
Smoked
06-10-2008 05:14 PM
TT
05-06-2008 06:49 AM
rwrows
04-05-2008 11:01 PM
green75
08-13-2007 02:49 PM
Quick Reply: stereo display wont go out..draining my batt
