Strange ticking behind glove box
Old Jan 14, 2009 | 08:46 PM
PiTRiFF's Avatar
PiTRiFF is an unknown quantity at this point
Default Strange ticking behind glove box
When I am driving there is a strange ticking that sounds like a turn signal coming from behind the glove box. When I touch the brake pedal it stops and starts again when I take my foot off the break pedal. I looked behind the glove box and noticed a wire harness and a small black square that looks like it may be some type of fuse. Any ideas?
Old Jan 14, 2009 | 08:51 PM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
Default RE: Strange ticking behind glove box
That is a relay and I had one do that to me and the turn signal switch ended up going out man that was costly
Old Jan 14, 2009 | 08:52 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
I'm not sure of your year but I'm sure of the problem........................................... ....multi-function switch(too lazy to look up your previous post about your partially plugged heater code to see what year you have-makes no difference tho). Jerry[X(]
Old Jan 14, 2009 | 09:15 PM
PiTRiFF's Avatar
I just found a new assembly on ebay for $79 I think Ill grab it.
Old Jan 14, 2009 | 09:33 PM
NVANZEE's Avatar
I wouldn't recommend getting one of ebay. It might not last, so it might be cheaper in the long run to get a new oem one. I also have this same problem. Haven't replaced it yet since i dont have the money right now and it still works. You can also make it stop by moving the switch around alittle. I would wait till it breaks completly before replacing it. I havent noticed mine clicking for a while now.
Old Jan 15, 2009 | 06:59 AM
Also considering that, depending on year as previously stated, you may just have to replace the hazard switch on the top of the steering column to cure this problem (to the tune of ~$15 from the dealer), you may want to start there.
If you mess with the hazard switch (turn it on and off rapidly), does the clicking go away?
Mike F in Nebraska
May 10, 2014 07:32 AM
luvmymoneypit
13
Apr 24, 2013 08:31 AM
dj00140
Dec 14, 2011 01:58 AM
MT123
Mar 9, 2010 04:27 PM
p72lwor
16
May 12, 2008 11:43 AM
