Stripped fuel filter nut/replacement?
Old May 18, 2015 | 07:31 AM
Redtortoise38's Avatar
Redtortoise38 is on a distinguished road
Default Stripped fuel filter nut/replacement?
Hi. On my 01' Blazer, the previous owner stripped the 5/8" nut that went into the fuel filter. I'm just curious if I can replace this without having to replace the entire fuel line. Could someone please lead me in the right direction? Thanks.
Old May 18, 2015 | 09:48 AM
Dorman #800-170 is availabe at most auto parts stores. You will need a 3/8" compression union to connect it to your existing steel line.
Old May 18, 2015 | 10:54 AM
3/8" compression union? Also how much does the Dorman typically run? Thanks for the info.
Old May 18, 2015 | 04:33 PM
Old May 18, 2015 | 04:41 PM
Cool man. I guess I just don't understand how the parts work (together).
Old May 18, 2015 | 06:12 PM
The Dorman line goes on the filter. Install one line nut over the Dorman line, then the ferrule. Attach one end of the union to the Dorman line and tighten the nut. Carefully measure and cut the steel line on the vehicle. It must fit all the way into the union. Install the other line nut on the vehicle steel line, then the ferrule. Insert the vehicle steel line into the union, and tighten the nut. Once you have the parts, you'll understand how it works.
PseudoKirby
Jun 22, 2011 07:13 PM
banshee386
Oct 9, 2008 07:32 PM
bertrenolds
Apr 14, 2008 08:13 PM
1989blazed
Mar 24, 2008 11:38 AM
whheezzzz
Jun 14, 2007 08:13 PM
