Stripped fuel filter nut/replacement?
Hi. On my 01' Blazer, the previous owner stripped the 5/8" nut that went into the fuel filter. I'm just curious if I can replace this without having to replace the entire fuel line. Could someone please lead me in the right direction? Thanks.
3/8" compression union? Also how much does the Dorman typically run? Thanks for the info.
The Dorman line goes on the filter. Install one line nut over the Dorman line, then the ferrule. Attach one end of the union to the Dorman line and tighten the nut. Carefully measure and cut the steel line on the vehicle. It must fit all the way into the union. Install the other line nut on the vehicle steel line, then the ferrule. Insert the vehicle steel line into the union, and tighten the nut. Once you have the parts, you'll understand how it works.
bertrenolds
Apr 14, 2008 08:13 PM
1989blazed
Mar 24, 2008 11:38 AM
whheezzzz
Jun 14, 2007 08:13 PM
