Stubborn Crank, No Start
Old Mar 18, 2019 | 09:15 AM
GeorgeLG's Avatar
Originally Posted by swartlkk
Coil, ICM, CKP, and injectors are all powered through the ECM1 fuse in the underhood fuse box. Is this fuse good? If it is, do you have +12V at this fuse in the START & RUN key positions?
You will need to work your way back from the coil through the ICM to the PCM as well as the sensors and power needed for spark. Looks like swartllk has you on the right track. If all your fuses and power are good then we can dive deeper.if you have nothing at the coil primary then cap and rotor are not the issue.
george
Old Mar 18, 2019 | 09:56 AM
varnerventures's Avatar
varnerventures is on a distinguished road
All fuses are good
Old Mar 18, 2019 | 12:18 PM
GeorgeLG's Avatar
Do you have 12V at the pink wire into the ICM with key on?
Pls confirm no 12V at pink wire into the coil; at key on.
Use battery ground not the ICM ground when measuring.
George
Old Mar 18, 2019 | 11:01 PM
Topher Faulkner's Avatar
Topher Faulkner is on a distinguished road
Had this exact issue in my 99 Blazer. Ended up fixing it eventually, after a lot of wasted money on parts. Come to find out the fuse box and particularly the lower level where the red honeycomb section where the wiring harness ties into the underside of the fuel pump relay. The power wire for the fuel pump was corroded and had burned up a little and was not making a good connection. Cleaned it up and tied it back in. Starts every time and haven’t had an issue since. This was over a year ago.
Old Mar 19, 2019 | 02:07 AM
Mike.308's Avatar
Originally Posted by Topher Faulkner
Had this exact issue [...]
Not really. OP has already reported a missing spark.
Old Mar 19, 2019 | 10:07 AM
GeorgeLG's Avatar
What mike said. We have an ignition problem, let’s stay focused to help the OP.
George
Old Mar 20, 2019 | 02:29 PM
With key on No voltage at pink wire on coil. No voltage at ECM fuse. Crawled underneath steering column im assuming its the pink that feeds this circuit there ws nothing there either
Old Mar 22, 2019 | 11:15 AM
GeorgeLG's Avatar
If you do not have power to the input of the ECM fuse then you don't have an ignition problem you have a power problem. When you go to key on/run does your dash respond or any other evidence that your ignition switch is providing run power to any system in the truck? What is your battery voltage?
George
Old Mar 22, 2019 | 11:40 AM
The ECM I circuit seems to be the only one effected. Fuel pump cycles batt gauge moves but the others are dead. No gear indicator lights come on either I think I read trans is on that circuit as well. Batt has 12.1V
Old Mar 22, 2019 | 11:42 AM
Check engine light never illuminates either I believe I read somewhere the OBD link is also is powered from that circuit
