Stuck in 4 hi
Old Sep 22, 2013 | 11:16 PM
vette_1989's Avatar
vette_1989 is on a distinguished road
Unhappy Stuck in 4 hi
I have a 2001 Blazer and today I put the truck in 4 Hi to pull my boat out of the water. After I got the boat out I pushed the 2 Hi button, the light flashed several in the 2 Hi button then when back to the light in the 4 Hi button. I can push the AUTO 4 WD button and that light will stay on, but the truck still fells like it is in 4 Hi. I need help
Thanks,
Joe
Old Sep 22, 2013 | 11:37 PM
pensfan74's Avatar
pensfan74 is on a distinguished road
I had that same problem with my 2000 blazer. It could be your TCCM (transfercase control module) which is located passenger side kick panel, your selector switch itself, vaccum actuator under your battery, or your shift motor which is located under your truck. I went through the process of elimination with mine and it ended up being the shift motor. I installed a new one and now it works fine. Hope that helps. Good Luck.
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
Takila Sunrise
May 25, 2006 11:40 PM
jwm1676
Engine & Internal
Jan 12, 2005 12:50 AM
