General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Brake Lights Stuck On! Help!
Old Jun 25, 2005 | 06:49 PM
Takila Sunrise's Avatar
Takila Sunrise is an unknown quantity at this point
Default Brake Lights Stuck On! Help!
I have a '97 Blazer LS 4WD. Fuse blew for brake/hazard lights after plugging in trailer lights. Replaced fuse, now brake lights stay on constantly, even when car is shut off! Replaced brake light switch (we feel we adjusted it correctly). Didn't fix it. Disconnected trailer lights wiring harness. Didn't fix it. I have to pull the fuse to turn brake lights off so it don't kill the battery. Running lights, hazard lights and turn signals work fine. It has my husband and I totally baffled and getting very frustrated. Kind of scary to drive because I don't want to get rear-ended or get pulled over. I have been searching the internet hoping to find a solution, but most of the answers have to do with replacing the brake light switch. Someone mentioned that they tapped on the relay under the hood and the lights went off, they replaced it and haven't had any problems since. When I tried to find out where this "relay" was located, couldn't find anything. I hope someone can point us in the right direction. Thanks in advance for any advice!
Old Jun 30, 2005 | 11:18 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: Brake Lights Stuck On! Help!
On my 97 the relays are ont the firewall and say Bosch and on my 87 they are on the drivers side above the wheel.
chris
Old May 25, 2006 | 10:01 PM
wix96's Avatar
wix96 is an unknown quantity at this point
Hey Takila,
Did you ever find out exactly what you needed to replace to fix the issue. I have a friend with the same problem? Please advise. Thanks.
Old May 25, 2006 | 11:40 PM
Wix, please post a new thread on this topic. This thread is OLD!!! Anyway, there is other information on this and other similar issues in other threads as well. If you need wiring help, please let me know. I have access to the diagrams for many different years.
Thread LOCKED!
richardhurtsher
Aug 9, 2011 09:40 AM
Denominator
Jul 9, 2011 09:07 PM
metal4fun
Apr 27, 2011 03:03 PM
Havensk
Jul 25, 2010 08:16 PM
TJK
Jun 24, 2009 11:16 AM
