stuck in 4 lo
Old Feb 18, 2007 | 10:27 PM
eelding's Avatar
eelding is an unknown quantity at this point
Default stuck in 4 lo
i am new here i have a 99 blazer that is stuck in 4 low i have serched this site and many others but still left with questions what motor or vacume lines work what, how do you know if your tccm i working where are the vacume lines on the fire wall,, any help would be apreaciated thankyou
Old Feb 18, 2007 | 10:47 PM
20Blazer00's Avatar
Default RE: stuck in 4 lo
If you are stuck in 4lo then you will have to check the voltage at the TCCM and check the Encoder motor on the transfer case. The Encoder motor is located next to the front output shaft on the transfer case it is a large rectangular motor with wires coming out you could use a DVMM to test for voltage to the motor if there is no voltage then you should consider the TCCM under the dash also search the forum on how to check for trouble codes from the TCCM...
Old Feb 20, 2007 | 10:14 AM
guywm25's Avatar
guywm25 is an unknown quantity at this point
This may seem like a stupid question, but are all four of tires the same size? If not this could be the problem even if you put your spare on that is not the same size, your 4low will not disengage.
Old Feb 20, 2007 | 12:50 PM
axe124's Avatar
axe124 is an unknown quantity at this point
This just happened to my wife's 2001 blazer. Dealer replaced the encoder motor. Good thing for extended warrenty. It would have cost $684.00.
Scott
Old Feb 21, 2007 | 09:34 PM
iturnrocks's Avatar
iturnrocks is an unknown quantity at this point
I had this happen recently on my 01 blazer. Lucky for me, all I had to do was replace the switch in the dash. Cost me about $38 for the part.
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
Takila Sunrise
May 25, 2006 11:40 PM
jwm1676
Engine & Internal
Jan 12, 2005 12:50 AM
